95 firebird taillights
  • 95 firebird taillights
    Does anyone know what years and trims taillights will fit in a 95 firebird
    Im not sure on the yearly specific changes as far as appearance, but the 1993 to 2002 tail lights would fit.
    someone else may chime in with more known specifics.
    Al
      So 98 trans am taillights should fit
        yes, the rear body stayed the same, im just not really familiar with exact styling design (looks) I cant be sure if you might want to change entire assembly as the center filler panel styles may need to be changed to match as well.
        Al
          Re: 95 firebird taillights
          Filler panels are same 93-02. Just different Fonts on wording. Tail lights will work from 93-02, like 35th stated.
            AFAIK, base model Firebirds were solid red taillights.....T/As with LT1s had what can only be described as a black grille like or slotted pattern and the LS1 cars of course had the honeycomb style pattern on them.
            LarryMow-93 V6 Firebird-No engine mods-Z06 Wheels, '98 Taillights,'98 Center Console-SLP fan switch-BMR STB, F/R Swaybars, PHB,LCA,Torque Arm, SFC, Bilsteins, Eibachs....www.cardomain.com/ride/2489691/1
