F-Body Message Board
Go Back   F-Body Message Board > F-Body > F-Body Tech Message Forum
User Name
Password
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Reply
Thread Tools Search this Thread Rate Thread Display Modes
  #1
Old 11-10-2007, 08:05 AM
95greengobblin 95greengobblin is offline
Registered User
CAM SHAFT
Just wanted to get a few thoughts on what is the best cam shaft for the money right now. I have a 95' z28, 6spd...mildly modded: 52 mm Holley, cold air intake, heads have been re-worked 2.00-intake 1.55-exhaust, msd distributor and wires, 4.10 gears, underdrive pulleys, hypertech, and will buy a new set of valve springs and 1.6 rockers when I purchase my cam. I'm wanting something that is going to be lumpy, but still allows for a reliable daily driver.
Also, what is a good. stock oem replacement flywheel?
  #2
Old 11-11-2007, 02:48 PM
Dragkid1917 Dragkid1917 is offline
Registered User
i know alot more bout cams in an LS1, but Id say anything with a high 22X to a low 23X duration, and anything over about a .575 lift and something with a 111 - 113LSA will give you alot of power and a nnnnnnice little lump.... Heer's my 233/239 .598/.603 on a 112 LSA..... http://videos.streetfire.net/video/...9be0144514a.htm
__________________
[COLOR=Navy]2000 Navy Blue Trans Am, T Tops, Automatic, Ram Air, Slp 85mm Mas, Air Lid, Smooth bellow, Hooker 1.75 Lt's, ORY, LM1, Air/EGR delete, Throttle body coolant bypass. Msd super conductor wires. TSP cam, ss3600, svo 38LB injectors.
Ported fast 92 mm intake and 92 mm TB on order.
11.539 @ 118.82 1.649 60 foot.
1969 z28 - 9.957 @ 133.92 1.425 60 foot.
  #3
Old 11-11-2007, 03:22 PM
SeanC SeanC is offline
Registered User
I'm jealous...my car sounds like a ricer compared to yours! haha nice car dude
  #4
Old 11-12-2007, 01:08 AM
ConElite's Avatar
ConElite ConElite is offline
Mad wit tols Not Chopstix
Quote:
thats the sound im after
__________________
Eddie
2000 M6 Trans Am T-Tops- K&N Element- SLP Lid
LS7 Clutch/LS2 FW - Hurst Line-Lock
Loud Mouth I cat Back System - KYB AGX 8-Way-BMR PH -UMI 35mm Solid Front SB - UMI ReLocation Brackets - UMI Short Shorter - UMI QA1 Single Sided Spherical Rod Control Arms - UMI Boxed Weld-In Subframe connectors
Energy Suspension Front A-Arm bushing Kit -
13.33@105 -2.16 60' - 314wrhp/328tq STOCK!
  #5
Old 11-13-2007, 12:29 PM
Registered User
for anyone who wants that sound, not trying to advertize for texas speed. But its really very simple. Pick a specific cam, as part of one of there 2 packages (spring kit differes between the two, anything over a .600 lift will require the bigger package) Ported oil pump, Dual timing chain, Arp Crank bolt, and the cam shaft swap package (consists of nessasary gaskets and whatnot) Its like.... 1100 total, and thats everything you need. You however may need bigger injectors witch is another 400... but.... its 1100 to have that sound and power 100% safley.
__________________
  #6
Old 11-13-2007, 03:52 PM
Injuneer's Avatar
Injuneer Injuneer is offline
Moderator
Are you sure that's an LT1 package? To run a true double roller timing chain on an LT1, you have to convert to an electric water pump. And I've seen people use a stock oil pump (albeit blueprinted, with the 80psi spring) on LT1's producing as much at 1,125HP. I run a stock pump and pan with my 800HP nitrous stroker.
__________________
1994 Formula - 381ci/300-shot N2O/TH400/Gear Vendor OD - 11.1@127.6 on a 125-shot -
Detailed Mod's List - - - - Step into my office.... - - - - Trailer Queen......
Website moved to new location:
http://www.injuneer.com/
  #7
Old 11-13-2007, 08:45 PM
Registered User
it was an LS1 combonation. I just everyone who replied beond the first guy with an Lt1 looked to have an ls1 or maybe i just went off on a tangent.
__________________
  #8
Old 11-14-2007, 06:21 AM
Injuneer's Avatar
Moderator
LS1 and LT1 camshaft designs/requirements are significantly different.
Wihtout knowing the specifics of his head work, its sort of hard to recommend a cam. And the definition of "streetable" differs widely. Seems like people want a radical, lumpy idle, then get concerned when they can't get the A/F ratio right at idle, and get surging under cruise conditions.
  #9
Old 11-14-2007, 12:59 PM
Registered User
i didnt know it was that different, but i guess now that i think about it the whole intake is different along with obviously the heads. I knew you couldnt fit an ls1 cam in an lt1 or something like that, someone just commented on the sound, and i thought they had an LS1 (conelite) so i told em what i did. But the surging thing was infact a problem untill I had cartek spend like 45 minuts tuning the idle.
__________________
  #10
Old 11-14-2007, 07:11 PM
ConElite's Avatar
I was speaking about the LS1.
LSx and LTx engines are very different when it comes to the heads and manifold. As for the Bolt im not going to pretend I know so ill stay quiet and .
__________________
Eddie
  #11
Old 11-14-2007, 09:39 PM
MunsonGTA MunsonGTA is offline
too slow too funny
i'd look for something in the 230 duration area, 112 lsa, and a powerband of 2000/2500-6000/6500. 112 lsa is about the best you can get with a "lumpy cam" and still pretty streetable. to get serious lump like most people want, you have to go down to the 110 lsa, which eats much more fuel, and is much harder to tune. you do get more power from the switch down to 110 lsa, just less "streetable"
__________________
87 GTA: it's winter time, all tore apart
ConElite: "Im 22, have had my TA since I was 21."
"I wont lie, I have a heavy foot, but at the same time I know when its the safest to ring out a gear or 2."
Reply
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by: vBulletin Version 3.0.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© Molten Systems, LLC - Privacy Policy
