Hey everyone, I've done a search on a few forums (including this one) about some problems i'm having with my 99 formula m6 but can't quite seem to find the same situation.
I just replaced the clutch, pressure plate, flywheel, and the throw out bearing along with a new pilot bearing this weekend.i'm having the same problem as before though. I'm hearing a whirring sound coming from what sounds like the transmission.as if the clutch is rubbing against the flywheel the whole time im driving. whenever i hit a bump the sound gets louder everytime the car drops. and she is getting hard to put into gear, especially reverse (the whole damn car shakes when i pretty much force her into gear)
Im almost positive i need to replace the pinion bearing as well due due ANOTHER whirring sound coming from the rear end (i've already replaced the carrier bearings which were pitted and have ruled out the axle shaft bearings)
I'm wondering if since im having problems changing gears, almost like the pedal isnt engaging properly if it's the slave cylinder going bad/on its last leg.
she's my dd so i'd really not want to take her to the stealership.
I did not replace the master or slave cylinder , which is what a few of my gear head friends are tellin me I should change ( the slave cylinder) and the back tires spin when I shift into first with the rear end up
I replaced the clutch with the duralast replacement set. Something to tide me over until I fixed everything that was wrong with her... Or so I thought I could.
When I finally get it in gear everything catches fine
Driving from work sucked today too, there's no physical way i can down shift while driving on the highway unless i pump on the clutch. That is actually the only way i can shift with the least resisitance.
